Apple iPhone 6
Using Do Not Disturb
Step 1 of 11
Press Do Not Disturb.
Step 2 of 11
Step 3 of 11
Press the indicator next to "Manual" to turn the function on or off.
Step 4 of 11
Press the indicator next to "Scheduled" and follow the instructions on the screen to select the required period for Do Not Disturb.
Press Allow Calls From.
Step 5 of 11
Press the required setting to select which contacts can call you even though Do Not Disturb is turned on.
Step 6 of 11
Step 7 of 11
Step 8 of 11
Press the indicator next to "Repeated Calls" to turn the function on or off.
Press Always if you want to set your phone to silent mode permanently.
Step 9 of 11
Press Only while iPhone is locked if you want to set your phone to silent mode only when the screen lock is turned on.
Step 10 of 11
Step 11 of 11
