Samsung Galaxy A8 2018
Using your phone as Wi-Fi hotspot
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Step 1 of 19
Step 2 of 19
Press Connections.
Step 3 of 19
Press Connections.
Press Mobile Hotspot and Tethering.
Step 4 of 19
Press Mobile Hotspot.
Step 5 of 19
Step 6 of 19
Press Configure Mobile Hotspot.
Step 7 of 19
Press the field below
Step 8 of 19
Press the field below "Network name" and key in the required name.
Step 9 of 19
Press the drop down list below "Security".
Press WPA2 PSK to password protect your Wi-Fi hotspot.
Step 10 of 19
The password prevents others from accessing your Wi-Fi hotspot without your approval.
Step 11 of 19
Press the field below "Password" and key in the required password.
Press SAVE.
Step 12 of 19
Press SAVE.
Step 13 of 19
If Wi-Fi is turned on, press OK.
Step 14 of 19
Step 15 of 19
Step 16 of 19
Step 17 of 19
Step 18 of 19
Step 19 of 19
