Samsung Galaxy Note8
I can't use my phone's internet connection
If you can't use the phone's internet connection, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to use the phone's internet connection.
Can you make a voice call?
