true
shop.ee.co.uk
id.ee.co.uk
myaccount.ee.co.uk
https://myaccount.ee.co.uk/login-dispatch?fa=logout
https://shop.ee.co.uk/authorize/log-out
https://id.ee.co.uk/id/logout
CHOOSE WHICH TYPE OF BUSINESS YOU ARE:
Small business
I am a sole trader or business with up to 50 employees
OR
Large business
I am a business with more than 50 employees
Toggle menu Search
Samsung Galaxy Note8
Turn GPS on or off
Step 1 of 10
Step 2 of 10
Step 3 of 10
Press Connections.
Step 4 of 10
Press Location.
Step 5 of 10
If you turn on geotagging, your phone can find your position using GPS. If you turn off the function, you can't use any GPS functions on your phone.
Step 6 of 10
Press Locating method.
Step 7 of 10
If you select High accuracy, your phone can find your exact position using the GPS satellites, the mobile network and nearby Wi-Fi networks. Satellite-based GPS requires a clear view of the sky.
Step 8 of 10
If you select Battery saving, your phone can find your approximate position using the mobile network and nearby Wi-Fi networks.
Step 9 of 10
If you select Phone only, your phone can find your exact position but it may take longer as there is no access to supplementary information from the mobile network or nearby Wi-Fi networks.
Step 10 of 10
