Samsung Galaxy S7 edge
I can't send and receive email messages
It's important to find out if you can use the phone's internet connection. If you can't use the phone's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive email messages.
Can you use the phone's internet connection?
