Samsung Galaxy S7 edge
Backing up pictures and video clips to Google Drive
You can back up pictures and video clips to Google Drive to ensure that no data is lost when you update your phone's software or if you lose your phone. To back up your pictures and video clips, you need to set up your phone for internet.
Press Apps.
Step 1 of 11
Press Apps.
Press Gallery and go to the required folder.
Step 2 of 11
Press and hold the required picture or video clip.
Step 3 of 11
Press All.
Step 4 of 11
Press All.
Press SHARE.
Step 5 of 11
Press SHARE.
Press Save to Drive.
Step 6 of 11
Press the field below
Step 7 of 11
Press the field below "Folder" and go to the required folder.
To create a new folder, press the new folder icon and follow the instructions on the screen to create a new folder.
Step 8 of 11
Press SELECT.
Step 9 of 11
Press SELECT.
Press SAVE.
Step 10 of 11
Press SAVE.
Step 11 of 11
