Samsung Galaxy S8+
I can't use my phone as a Wi-Fi hotspot
It's important to find out if you can use the phone's internet connection. If you can't use the phone's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to use your phone as a Wi-Fi hotspot.
Can you use the phone's internet connection?
