Alcatel
1b 2022
Alcatel 1b 2022
f-98ecd4aa-701f-495b-82c9-9d6efbb7e6f2
f-c62c06df-4281-423c-be3e-ac0f9dcc6199
f-cfe26b85-6774-4284-9057-70e0c40817c5
f-9bbf101e-cbd6-4576-b843-59b45d40cc83
f-96da1fc5-829f-42cf-87cc-0032686fb708
f-45eebbec-d385-4d24-85d1-2db5514c68d1
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
