Alcatel
1b 2022
Alcatel 1b 2022
f-98ecd4aa-701f-495b-82c9-9d6efbb7e6f2
f-c62c06df-4281-423c-be3e-ac0f9dcc6199
f-cfe26b85-6774-4284-9057-70e0c40817c5
f-9bbf101e-cbd6-4576-b843-59b45d40cc83
f-96da1fc5-829f-42cf-87cc-0032686fb708
f-45eebbec-d385-4d24-85d1-2db5514c68d1
Can you make a voice call?
