Alcatel
1s 2021
Alcatel 1s 2021
f-07f1cb78-85b1-4b77-bf6c-d043b9d0f1fb
f-6dc2b069-ed67-45a6-8c13-77ff7780d9e1
f-528fe775-77c7-436c-a685-082be3b7b51b
f-50cd58e0-fce2-428b-84d5-50c9219f6051
f-4f4e62ad-ee17-4981-a7c2-f6ca50d2b5c8
f-00dbf814-2ee3-429e-8abc-c19e26ac7794
Can you make a voice call?
