Alcatel 1s 2021
Solution 1 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Press SIM card & mobile network.
Press Hotspot & tethering.
Press Mobile hotspot.
Press Hotspot name and key in the required name for the Wi-Fi hotspot.
Press OK.
Press Security.
Press WPA-2 Personal to password protect your Wi-Fi hotspot.
Press Hotspot password and key in the required password.
Press OK.
Press the indicator below "Mobile hotspot" to turn on the function.
