Apple iPhone 11 Pro
Using Dark Mode
You can set your phone to use a dark theme so you can use your phone in dark surroundings and not inconvenience other people. Furthermore, you can create a schedule for automatic change of theme at certain times.
Step 1 of 6
Press Display & Brightness.
Step 2 of 6
Press Dark.
Step 3 of 6
Press Dark.
Step 4 of 6
Press the indicator next to "Automatic" to turn the function on or off.
If you turn on the function, press Options and follow the instructions on the screen to select the required period of time for Dark Mode.
Step 5 of 6
Step 6 of 6
