iPhone 11 Pro
It's not possible to use my phone as a personal hotspot
If you can't use your phone as a personal hotspot, there may be several causes of the problem.
It's important to find out if you can use your phone's internet connection. If you can't use your phone's internet connection, you need to solve this problem first. When the problem is solved, you will most likely also be able to use your phone as a personal hotspot.
