iPhone 11 Pro
Using Control Centre
Using Control Centre, you can get quick access to selected functions on your phone.
Step 1 of 4
Press the required function to open an application or turn the function on or off.
Step 2 of 4
Slide your finger up or down on the required function to select the required setting.
Step 3 of 4
Step 4 of 4
x
Get information on
Or select
Another device
