iPhone 11 Pro
Using Face ID
You can set your phone to use face recognition as phone lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Done. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
Press the indicator next to "iPhone Unlock" to turn the function on or off.
If you turn on the function, you can use your Face ID to turn off the phone lock code.
Press the indicator next to "iTunes & App Store" to turn the function on or off.
If you turn on the function, you can use your Face ID to authorise iTunes and App Store purchases.
x
Get information on
Or select
Another device
