iPhone 11 Pro Max
Turning GPS on or off
Press Privacy.
Press Privacy.
Press Location Services.
Press the indicator next to "Location Services" to turn the function on or off.
If you turn on this function, your phone can find your exact position using GPS. If you turn off the function, you can't use any GPS functions on your phone.
Press the required app.
x
Get information on
Or select
Another device
