iPhone 11 Pro Max
Backing up phone memory to iCloud
You can back up the phone memory to iCloud to ensure that no data is lost when you update your phone's software or if you lose your phone. To back up the phone memory to iCloud, you need to activate your Apple ID on your phone and establish a connection to a Wi-Fi network.
Press your Apple ID.
Press iCloud.
Press iCloud.
Press iCloud Backup.
Press the indicator next to "iCloud Backup" to turn on the function.
The phone memory will be backed up automatically when your phone is charging, the screen lock is turned on and a Wi-Fi connection is established.
Press Back Up Now and wait while the phone memory is backed up.
x
Get information on
Or select
Another device
