iPhone 11 Pro Max
Using notifications
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
Step 1 of 16
Press Notifications.
Step 2 of 16
Press Show Previews.
Step 3 of 16
To select notification preview on the lock screen, press Always.
Step 4 of 16
To select notification preview only when your phone is unlocked, press When Unlocked.
Step 5 of 16
To turn off notification preview, press Never.
Step 6 of 16
Press arrow left.
Step 7 of 16
Press arrow left.
Press the required application.
Step 8 of 16
Step 9 of 16
Press the indicator next to "Allow Notifications" to turn notifications for the selected application on or off.
Press Notification Grouping.
Step 10 of 16
This function enables you to select whether notifications should be grouped or be displayed individually.
Press the required setting.
Step 11 of 16
Press arrow left.
Step 12 of 16
Press arrow left.
Step 13 of 16
Step 14 of 16
Press the required notification and follow the instructions on the screen to use the selected function.
Step 15 of 16
Step 16 of 16
