iPhone 11 Pro Max
Using Screen Time
Using Screen Time you can get an overview of how much you use your phone and set time limits on the use of selected apps. To use the function, you need to turn on Screen Time.
Step 1 of 13
Press Screen Time.
Step 2 of 13
Press Screen Time.
Press See All Activity.
Step 3 of 13
The use for the past week is displayed next to Total Screen Time.
Step 4 of 13
Press Day.
Step 5 of 13
Press Day.
Today's use is displayed.
Step 6 of 13
Press arrow left.
Step 7 of 13
Press arrow left.
Step 8 of 13
Press the indicator next to "Share Across Devices" and follow the instructions on the screen to turn total Screen Time across all of your devices on or off.
If you turn on the function, you can see Screen Time for all of your devices.
Press Ignore Limit.
Step 9 of 13
You will be notified if you've used all your assigned Screen Time. You can then choose to assign more Screen Time.
Press Ignore Limit.
Press the required setting.
Step 10 of 13
Press Turn Off Screen Time.
Step 11 of 13
Step 12 of 13
Step 13 of 13
x
Get information on
Or select
Another device
