iPhone 11 Pro Max
Setting up your phone for POP3 email
You can set up your phone to send and receive email messages from your email accounts. Using POP3, your email messages are retrieved to your phone and at the same time they are deleted from the server. You're then not able to access your email messages from other devices. To set up your phone for POP3 email, you need to set up your phone for internet.
Step 1 of 42
Press Mail.
Step 2 of 42
Press Mail.
Press Accounts.
Step 3 of 42
Press Accounts.
Press Add Account.
Step 4 of 42
Press Add Account.
Press Other.
Step 5 of 42
Press Other.
If the name of your email provider is on the list, press this instead.
Press Add Mail Account.
Step 6 of 42
Press Name and key in the required sender name.
Step 7 of 42
Press Email and key in your email address.
Step 8 of 42
Step 9 of 42
Press Description and key in the required name.
Step 10 of 42
Press Next.
Step 11 of 42
Press Next.
Step 12 of 42
Press POP.
Step 13 of 42
Press POP.
Press Host Name and key in the name of your email provider's incoming server.
Step 14 of 42
Press Username and key in the username for your email account.
Step 15 of 42
Press Host Name and key in the name of your email provider's outgoing server.
Step 16 of 42
Step 17 of 42
Step 18 of 42
Press Save. Your email account has now been set up. To select more settings for incoming and outgoing server, proceed with the following steps.
Step 19 of 42
Press the name of the email account you've just set up.
Step 20 of 42
Press SMTP.
Step 21 of 42
Press SMTP.
Press the field below
Step 22 of 42
Press the field below "PRIMARY SERVER".
Step 23 of 42
Press the indicator next to "Use SSL" to turn off the function.
Press Authentication.
Step 24 of 42
Press Password.
Step 25 of 42
Press Password.
Press arrow left.
Step 26 of 42
Press arrow left.
Press Server Port and key in 25.
25
Step 27 of 42
Press Done.
Step 28 of 42
Press Done.
Press arrow left.
Step 29 of 42
Press arrow left.
Press Advanced.
Step 30 of 42
Press Advanced.
Step 31 of 42
Step 32 of 42
Press Password.
Step 33 of 42
Press Password.
Press arrow left.
Step 34 of 42
Press arrow left.
Press Server Port and key in 110.
110
Step 35 of 42
Press arrow left.
Step 36 of 42
Press arrow left.
Press Done.
Step 37 of 42
Press Done.
Press Fetch New Data.
Step 38 of 42
Step 39 of 42
Press the indicator next to "Push" to turn the function on or off.
If you turn off the function, press the required setting.
Step 40 of 42
Press the required email account and follow the instructions on the screen to select settings for the specific account.
Step 41 of 42
Step 42 of 42
x
Get information on
Or select
Another device
