iPhone 11 Pro Max
Using your phone as a personal hotspot
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press Done.
Step 4 of 12
Press Done.
The password prevents others from accessing your Wi-Fi hotspot without your approval.
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPhone 11 Pro Max
Step 9 of 12
Step 10 of 12
Step 11 of 12
Step 12 of 12
x
Get information on
Or select
Another device
