iPhone 11 Pro Max
Using App Library
All apps on your phone are automatically organised by category in the App Library. You can set your phone to display newly downloaded apps on both the home screen and in the App Library and also adjust the number of home screens for a better overview of your apps.
Step 1 of 14
Press Home Screen.
Step 2 of 14
Press Home Screen.
To add new downloaded apps to both the home screen and App Library, press Add to Home Screen.
Step 3 of 14
To add new downloaded apps to the App Library only, press App Library Only.
Step 4 of 14
Step 5 of 14
Slide your finger left on the screen to find the App Library.
Step 6 of 14
Press the required app.
Step 7 of 14
Press the search field and follow the instructions on the screen to search for the required app.
Step 8 of 14
Step 9 of 14
Press and hold any home screen until the icons start to jiggle.
Step 10 of 14
You can adjust the number of home screens on your phone. Apps on deselected home screens are only displayed in the App Library.
Press the home screen icon.
Step 11 of 14
Press the fields below the required home screens to select or deselect them.
Step 12 of 14
Press Done.
Step 13 of 14
Press Done.
Press Done.
Step 14 of 14
Press Done.
x
Get information on
Or select
Another device
