iPhone 12 Pro Max
Selecting Screen Time settings
Using Screen Time you can get an overview of how much you use your phone and set time limits on the use of selected apps.
Step 1 of 41
Press Screen Time.
Step 2 of 41
Press Screen Time.
Press Turn On Screen Time.
Step 3 of 41
Press Continue.
Step 4 of 41
Press Continue.
Press This is My iPhone.
Step 5 of 41
Press Downtime.
Step 6 of 41
Press Downtime.
Step 7 of 41
Press the indicator next to "Downtime and follow the instructions on the screen to select Downtime period.
During Downtime only calls and allowed apps will be available.
Press arrow left.
Step 8 of 41
Press arrow left.
Press App Limits.
Step 9 of 41
Press App Limits.
Press Add Limit.
Step 10 of 41
Press Add Limit.
Press the required categories.
Step 11 of 41
Press Next.
Step 12 of 41
Press Next.
Set the required time limit for use of the selected category.
Step 13 of 41
Press Customise Days.
Step 14 of 41
Press the required days.
Step 15 of 41
Select the required time limit.
Step 16 of 41
Press arrow left.
Step 17 of 41
Press arrow left.
Press Add.
Step 18 of 41
Press Add.
Press the required category.
Step 19 of 41
Press Delete Limit.
Step 20 of 41
Press Delete Limit.
Press Delete Limit.
Step 21 of 41
Press Delete Limit.
Press arrow left.
Step 22 of 41
Press arrow left.
Press Communication Limits.
Step 23 of 41
Press During Screen Time.
Step 24 of 41
Press the required setting.
Step 25 of 41
During Screen Time, only communication with allowed contacts is available.
Press arrow left.
Step 26 of 41
Press arrow left.
Press During Downtime.
Step 27 of 41
Step 28 of 41
During Downtime, only communication with allowed contacts is available.
If you select Specific Contacts, follow the instructions on the screen to select the required contacts.
Step 29 of 41
Press arrow left.
Step 30 of 41
Press arrow left.
Press arrow left.
Step 31 of 41
Press arrow left.
Press Always Allowed.
Step 32 of 41
Press the add icon next to the required app to add it to the list of allowed apps during Downtime.
Step 33 of 41
Press the remove icon next to the required app to remove it from the list of allowed apps during Downtime.
Step 34 of 41
Press Remove.
Step 35 of 41
Press Remove.
Press arrow left.
Step 36 of 41
Press arrow left.
Press Content & Privacy Restrictions.
Step 37 of 41
Step 38 of 41
Press the indicator next to "Content & Privacy Restrictions" and follow the instructions on the screen to select settings for content and privacy restrictions.
Press arrow left.
Step 39 of 41
Press arrow left.
Press Use Screen Time Passcode and follow the instructions on the screen to select a Screen Time password.
Step 40 of 41
If you turn on the function, you need to key in the password to access Screen Time settings.
Step 41 of 41
x
Get information on
Or select
Another device
