iPhone 12 Pro Max
Selecting network mode
Press Mobile Data.
Press Mobile Data.
Press Mobile Data Options.
Press Voice & Data.
Press Voice & Data.
To turn on use of 5G primarily, press 5G On.
Your phone will primarily use 5G even though it may cause an increase in battery consumption. Your phone automatically switches between 4G and 5G depending on whether you have 5G network coverage or not.
To turn on automatic switch between 5G and 4G, press 5G Auto.
Your phone will only use functions that do not have a significant impact on the battery consumption. Your phone automatically switches between 4G and 5G depending on whether you have 5G network coverage or not.
To use 4G only, press 4G.
x
Get information on
Or select
Another device
