iPhone 12 Pro Max
Solution 2 of 14: Automatic app update is turned on
You can select whether your apps should be updated to the newest version automatically or manually. See how to install an app.
Step 1 of 5
Press App Store.
Step 2 of 5
Press App Store.
Step 3 of 5
Press the indicator next to "App Updates" to turn the function on or off.
Step 4 of 5
Press the indicator next to "Automatic Downloads" to turn the function on or off.
Step 5 of 5
x
Get information on
Or select
Another device
