iPhone 13 Pro Max
iPhone 13 Pro Max
f-fec54e55-142d-488a-8b4c-347e02a908dd
f-d78914dd-197a-4e96-aec0-b8f75edca070
f-44c6d572-3578-413b-aa98-ae277e5f67ec
f-91529581-c161-4c66-a67b-530cd5010dcb
f-9a6b9905-60b1-4280-be71-ea5fb192a512
f-66ee72a0-2250-4ecb-8b92-270710eb70d2
Device home
Getting started
Basic functions
Calls, contacts, messaging
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
