iPhone 14 Pro Max
iPhone 14 Pro Max
f-d56c5cc8-2a6c-4b37-8a27-9bd0f1fcc52f
f-2c7d559d-d19a-48bd-a4b1-94362d8db40f
f-9b1bcdb5-8031-4c85-96e3-f2ce67a159a8
f-08f52ffe-e04d-4146-a24b-d48183d0a01c
f-d2481693-78e0-4d38-89b8-2c909adf0208
f-2ad5327e-1948-4825-95d0-43251d27829b
f-901232d2-4559-4115-918f-66fef8697af0
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
