iPhone 16 Pro Max
iPhone 16 Pro Max
f-bd356d62-013e-43d4-8cfc-02ea1e36deb2
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
Device home
Getting started
Basic functions
Calls, contacts, messaging
Using music player
You can use the music player to play audio files you have transferred to your phone.
Press the music player icon.
Step 1 of 17
Press Playlists.
Press Playlists.
Step 2 of 17
Press Playlists.
Press the new playlist icon.
Step 3 of 17
Press the text input field and key in a name for the playlist.
Step 4 of 17
Press Create.
Press Create.
Step 5 of 17
Press Create.
Press Add Music.
Press Add Music.
Step 6 of 17
Press Add Music.
Go to the required category and press the add icon next to the required audio file.
Step 7 of 17
Press Done.
Press Done.
Step 8 of 17
Press Done.
Go to the required category or playlist and press the required audio file.
Step 9 of 17
Step 10 of 17
Press the Volume keys to select volume.
Press the song title.
Step 11 of 17
Press arrow right to go to the next audio file.
Step 12 of 17
Press arrow left twice to go to previous audio file.
Step 13 of 17
Press the playback queue icon.
Step 14 of 17
Press the shuffle icon to turn the function on or off.
Step 15 of 17
Press the repeat icon to turn the function on or off.
Step 16 of 17
You can choose whether you want the music player to repeat one or more audio files.
Step 17 of 17
