iPhone SE (2020)
Selecting settings for Control Centre
Using Control Centre, you can get quick access to selected functions on your phone.
Press Control Centre.
Press the indicator next to "Access Within Apps" to turn the function on or off.
If you turn on the function, Control Centre can be used both on the home screen and while using other applications.
Press Customise Controls.
Press the delete icon next to the required function to remove it from Control Centre.
Press the add icon next to the required function to add it to Control Centre.
Press the move icon next to the required function and drag it to the required position in Control Centre.
x
Get information on
Or select
Another device
