iPhone X
Using Control Centre
Using Control Centre, you can get quick access to selected functions on your phone.
Step 1 of 4
Press the required function to open an application or turn the function on or off.
Step 2 of 4
You can also use 3D Touch for selected functions in Control Centre. You can see some examples of how to use 3D Touch.
Slide your finger up or down on the required function to select the required setting.
Step 3 of 4
Step 4 of 4
x
Get information on
Or select
Another device
