iPhone Xs
It's not possible to send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
x
Get information on
Or select
Another device
