iPhone Xs Max
Using 3D Touch
By varying the screen pressure intensity, 3D Touch allows you to access various application functions on your phone directly from the main menu and see e.g. pictures, messages and addresses without opening them.
Step 1 of 23
Press General.
Step 2 of 23
Press General.
Press Accessibility.
Step 3 of 23
Press 3D Touch.
Step 4 of 23
Press 3D Touch.
Step 5 of 23
Press the indicator next to "3D Touch" to turn on the function.
Press and drag the indicator below
Step 6 of 23
Press and drag the indicator below "3D TOUCH SENSITIVITY" right or left to set the required sensitivity for 3D Touch.
Step 7 of 23
Hard press and hold the required app until a pop-up menu is displayed.
Step 8 of 23
Press the required function and follow the instructions on the screen to use the selected function.
Step 9 of 23
You can use 3D Touch in the main menu for quick access to various application functions.
Press Photos and go to the required folder.
Step 10 of 23
Hard press and hold the required picture until a pop-up menu is displayed.
Step 11 of 23
Drag the picture upwards.
Step 12 of 23
Step 13 of 23
Press the music player icon and go to the required audio file.
Step 14 of 23
Hard press and hold the required audio file until a pop-up menu is displayed.
Step 15 of 23
Step 16 of 23
Press the message icon.
Step 17 of 23
Go to the required message.
Step 18 of 23
Hard press the screen to see a section of the required content.
Step 19 of 23
Press the screen a little harder until the content of the message is opened in the relevant application.
Step 20 of 23
Step 21 of 23
Hard press and hold the required function until a pop-up menu is displayed.
Step 22 of 23
Step 23 of 23
x
Get information on
Or select
Another device
