You can use the music player to play audio files you have transferred to your phone.
Press the music player icon.
You can also use 3D Touch in Music. You can see some examples of how to use 3D Touch.
Press Playlists.
Press New Playlist.
Press the text input field and key in a name for the playlist.
Press Add Music.
Go to the required category and press the required audio file.
Press Done.
Press Done.
Go to the required category or playlist and press the required audio file.
Press the Volume keys to select volume.
Press the song title.
Press arrow right to go to the next audio file.
Press arrow left to go to the previous audio file.
Press Shuffle to turn the function on or off.
Press Repeat to turn the function on or off.
