iPhone Xs Max
If you can't send and receive picture messages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive picture messages.
Can you make a voice call?
x
Get information on
Or select
Another device
