iPhone Xs Max
Selecting network mode
Press Mobile Data.
Press Mobile Data.
Press Mobile Data Options.
Press Enable 4G.
Press Enable 4G.
To turn off use of 4G, press Off.
Your phone automatically switches between 2G and 3G depending on whether you have 3G network coverage or not.
To use 4G for both voice calls and mobile data, press Voice & Data.
You can use 4G for voice calls via the mobile network for a faster and better connection.
To use 4G for mobile data only, press Data Only.
x
Get information on
Or select
Another device
