Doro
8050
Doro 8050
f-020e3c20-15b5-4f89-844f-2fd6772e308c
f-2f6fa83c-c733-4439-9746-6d256184918f
f-2e36d526-55d0-4f51-bc69-4b5a33675f3c
f-f7ec85e1-2b39-4aed-ae13-1df740b20493
f-8715b941-0390-4e25-b290-4ca784c7e7b2
f-c054c3b1-61c1-4831-96f6-74bfcc815a5a
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
