Doro
8050
Doro 8050
f-020e3c20-15b5-4f89-844f-2fd6772e308c
f-2f6fa83c-c733-4439-9746-6d256184918f
f-2e36d526-55d0-4f51-bc69-4b5a33675f3c
f-f7ec85e1-2b39-4aed-ae13-1df740b20493
f-8715b941-0390-4e25-b290-4ca784c7e7b2
f-c054c3b1-61c1-4831-96f6-74bfcc815a5a
If you can't send and receive picture messages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive picture messages.
Can you make a voice call?
