EE Smart Hub 7 Pro
Mac OS Sonoma
I can't establish a wireless connection to my router.
Solution 1 of 5: The name of your Wi-Fi hotspot is identical to another Wi-Fi hotspot name.
Your router comes with a default name which is used when you establish a connection to the internet using your Wi-Fi hotspot. You can change this name. Remember, you need to establish a connection to the router web interface.
