EE Smart Hub 7 Pro
Mac OS Sonoma
It's not possible to use my router as a Wi-Fi hotspot
Solution 3 of 4: Your router has been set up incorrectly
If your internet connection is slow or doesn't work as it usually does, it may help to restore the factory default settings. Please note that all settings in your router are deleted during this process. Remember, you need to establish a connection to the router web interface.
