EE
Smart Hub 7 Pro
EE Smart Hub 7 Pro
Mac OS Sonoma
Windows 11
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
The speed of the internet connection is lower than expected
Solution 1 of 4: You are downloading files using a peer-to-peer program
If you're downloading files using a peer-to-peer program, such as a BitTorrent client, you may experience low speeds.
Close the peer-to-peer program.
