EE
Smart Hub 7 Pro
EE Smart Hub 7 Pro
Mac OS Sonoma
Windows 11
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
Guide to router keys and sockets
The list below shows you what the different keys and sockets on your router are used for.
Press the WPS button to connect a WPS device.
Insert a sharp-pointed object (such as a paper clip) into the small hole next to
Insert a sharp-pointed object (such as a paper clip) into the small hole next to "Reset" and hold it for at least 10 seconds to restore the factory default settings.
Connect a USB device to the
Connect a USB device to the "USB" port.
Press On/Off to turn your router on or off.
Connect a phone to the
Connect a phone to the "Phone" port.
Connect your computer or game console to the
Connect your computer or game console to the "LAN" port.
Connect the network cable (red connector) to the
Connect the network cable (red connector) to the "WAN" port and the other end to the PORT1/LAN1 port on your Openreach modem.
Connect the power supply to the power plug and to a wall socket.
