EE Smart Hub 7 Pro
Windows 11
I can't establish a wireless connection to my router.
Solution 2 of 5: Wireless connections are turned off on your computer
If wireless connections are turned off on your computer, you can't establish a wireless connection to your router.
Turn on wireless connections on your computer.
