EE Smart Hub 7 Pro
Windows 11
I can't establish a wireless connection to my router.
Solution 3 of 5: The entered password is incorrect
If you've changed and lost the password for your router's Wi-Fi hotspot, it can be found in the router web interface. Remember, you need to establish a connection to the router web interface.
