EE
Smart Hub 7 Pro
EE Smart Hub 7 Pro
Windows 11
Mac OS Sonoma
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
It's not possible to use my router as a Wi-Fi hotspot
Solution 2 of 5: The wireless connection to your router's Wi-Fi hotspot is unstable.
If you experience an unstable wireless connection to your router's Wi-Fi hotspot, it may help changing the channel. Remember, you need to establish a connection to the router web interface.
Click Advanced settings.
Click Wireless and, if required, follow the instructions on the screen to key in the administrator password.
Click Rescan below the required Wi-Fi network and wait a moment while your router scans for the best available channel.
Click the drop down list next to
Click the drop down list next to "Channels:".
Click the required channel.
Click Set.
Click Set.
Click Set.
Click Save.
Click Save.
Click Save.
Click Yes. You can now establish a connection to your Wi-Fi hotspot using the new channel.
