EE Smart Hub 7 Pro
Windows 11
It's not possible to use my router as a Wi-Fi hotspot
Solution 3 of 5: The Wi-Fi hotspot password has been changed
Your router comes with a default password which is used when you establish a connection to the internet using your router's Wi-Fi hotspot. You can change this password. Remember, you need to establish a connection to the router web interface.
