EE Smart Hub 7 Pro
Windows 11
The speed of the internet connection is lower than expected
Solution 4 of 4: You're using a wireless connection to your router
You may experience low speeds if you're using a wireless connection to your router instead of an Ethernet cable.
Try establishing a connection to your router using an Ethernet cable instead.
