EE
Smart Hub Pro
EE Smart Hub Pro
Mac OS Sonoma
Windows 11
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
I can't establish a wireless connection to my router.
Solution 1 of 5: The name of your Wi-Fi hotspot is identical to another Wi-Fi hotspot name.
Your router comes with a default name which is used when you establish a connection to the internet using your Wi-Fi hotspot. You can change this name. Remember, you need to establish a connection to the router web interface.
Click Advanced settings.
Step 1 of 5
Click Wireless and, if required, follow the instructions on the screen to key in the administrator password.
Step 2 of 5
Click the field next to
Step 3 of 5
Click the field next to "Network name:" and key in the required name for your Wi-Fi hotspot.
Click Save.
Click Save.
Step 4 of 5
Click Save.
Click Yes.
Click Yes.
Step 5 of 5
Click Yes.
