EE
Smart Hub 7 Pro
EE Smart Hub 7 Pro
Windows 11
Mac OS Sonoma
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
Changing Wi-Fi hotspot password
Your router comes with a default password which is used when you establish a connection to the internet using your router's Wi-Fi hotspot. You can change this password. Remember, you need to establish a connection to the router web interface.
Click Advanced settings.
Step 1 of 11
Click Wireless and, if required, follow the instructions on the screen to key in the administrator password.
Step 2 of 11
You can see the administrator password behind the cover on the back of your router.
Click Show.
Click Show.
Step 3 of 11
Click Show.
Click the field next to
Step 4 of 11
Click the field next to "Security password:" and key in the required password.
Click Save.
Click Save.
Step 5 of 11
Click Save.
Click Yes.
Click Yes.
Step 6 of 11
Click Yes.
Click the menu field.
Step 7 of 11
If you change the Wi-Fi hotspot password, you need to remove the Wi-Fi hotspot in Windows as Windows will try to connect to the Wi-Fi hotspot using the old password.
Click arrow right next to the Wi-Fi icon.
Step 8 of 11
Click More Wi-Fi settings.
Step 9 of 11
Click Manage known networks.
Step 10 of 11
Click Forget next to the required Wi-Fi hotspot.
Step 11 of 11
Please note that the internet connection is ended and you need to establish a wireless internet connection again with the new settings.
