EE
Smart Hub 7 Pro
EE Smart Hub 7 Pro
Windows 11
Mac OS Sonoma
f-47e554b3-75c1-4487-b308-fc1cedee894a
f-76018886-9f8e-4db5-a990-aa003e19bfcc
f-52b50695-b922-4bf8-9b01-e372ed226696
f-fd8bd09b-dd62-4229-a858-eed4e940b9c9
f-f92d5337-512b-4fa9-bd04-3a9cbafc70de
The internet connection is unstable
Solution 3 of 5: You're using a wireless connection to your router
You may experience an unstable internet connection if you're using a wireless connection to your router instead of an Ethernet cable.
Try establishing a connection to your router using an Ethernet cable instead.
