FAIRPHONE
Fairphone 4
FAIRPHONE Fairphone 4
f-ae452b7e-b191-4b8c-8a74-33f300d40886
f-f1b523f4-aa36-421c-8d10-677618105a97
f-0fb2c5d3-5ba8-42c8-b0a4-cfd33cb28383
f-700ac667-2865-4810-b4c1-1c984dd9b1b3
f-e859d36b-0559-4a44-b330-6718367d5c20
f-9a01480e-fc42-4d4e-aa37-ab0d7b745431
Solution 6 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
